JeepinSteve
- Joined
- Oct 27, 2021
- Messages
- 32
- Reaction score
- 28
Hello. My 2004 Liberty is leaking from the firewall wiring harness on the drivers side just to the left of the clutch pedal as you can see in the picture. I put a hose to the bottom of the windshield and I could see the water flowing in. I know that wiring harness comes in from the engine bay and not under the cowl. When water flows off the bottom of the window, should it be able to make it into the engine bay? Is there a drain that is possibly draining into the engine bay. The seal that separates the engine from the cowl is in perfect condition, so It's not coming in from there. I will take off the cowl when I have time and run some water into it to see if I can figure it out. I'll also look at the bottom of the window to make sure the window is making a good seal. Anyone experience a leak from this area? Thanks.
