Zero402
Are they made straight or have a downward angle?
Yea, was curious if JBA made them to compensate for the lift. UCA's and LCA's should be at same angle for proper geometry of suspension and tire travel. Flat though, ok thanks![/QU
It makes everything work together
A mechanical engineer first came up with them ( his name was Al ) then Marlin owner of JBA who is also an engineer etc fine tuned them and has them
So yes they are correct and work well
I have installed 50 some sets of them, plus have over 180,000 miles on them in my two KJs . Have even watched them being made, so your concerns , well shouldn't be a concern at all
The 4.5's add strength & are a necessity once you have a decent suspension lift, and will make the alignment way better.
