is this normal?
jggv98
Monterrey
i found under the KJ on the front drive shaft (transfer side) like a grease leaking, i dont know if this is normal or do i have a problem with some seal
any comments?
kskj
Valley Center, Ks
Front drive shaft boot is bad (on the back). Need a new drive shaft. Or get that one rebuilt.
IN DEEE
i found under the KJ on the front drive shaft (transfer side) like a grease leaking, i dont know if this is normal or do i have a problem with the some seal
any comments?
spent about alot of money to fix mine
jggv98
Monterrey
thanks
It is easy to take off (remove) the front DS by my self?, it is only matter of remove the 6(8mm) bolts by side??? what else do i need to take off and/or disconnect?
jggv98
Monterrey
Thanks
Are all the driveshafts made for the KJ the same??? i mean, if i found a used one in some repair shop, ill be sure it fit to my 2004 KJ?
jggv98
Monterrey
new OEM drive shaft
i Just put yesterday my new Front DS, it was very easy, took 1.5 hrs
these are the pics
