jharrisliberty
Has anyone experienced a problem with their steering due to ice build up from driving on icy and snow packed roads? The steering issue only occurs when I am driving at slower speeds.
What kind of symptoms do you have? Mine just wobbles but that's because it switches between the tracks that are already on the road if that makes sense.
Never had any issues with mine and I've pushed snow up over the hood
are you sure you bled it right after installing the pump?
The only issue I have had is snow/ice packed in the rims throwing them out of balance and causing a wobble/shake. Seems to be much worse with the 20's on my Titan. I suppose if you had a lot of ice packed somewhere it shouldn't be and it freezes solid it could be a cause. I would take your KJ to a carwash and let it warm up and wash it pretty good and allow for it to dry a bit before taking it back out into the cold and see if the problem persists. I was out mudding once and got mud packed in the rims and she shook so hard I thought parts were going to fall off lol.
well, and im not a mechanic however, it sounds to me like 2 possibilities. Could be air in the system. Even a bubble that was trapped somewhere could cause an intermittent issue theoretically. try bleeding again. or, and if it is directly related to speed of the motor this issue acutally does make sense, the pump is not spinning fast enough at idle. if you get proper steering when adding throttle or driving at speed but not at idle then the pump is just not spinning fast enough. so possible causes could be loose belt, wrong size pulley(somehow), or just a faulty pump. just my .02
