how to make intake sound louder.
twack
rochester mn
well i posted my pics of my complete CAI and i like it a lot! little bit more responsive, plus the sound!! only problem now is scared of playing in the water....
just put a valve in the intake incase of sucking in SMALL bits of water
IN DEEE
K&Ns =no good on the KJ
tried one for 25,000 miles
and swapped it out for Amsoil in the stock box with 4 inch hose from the grill to the box, better mileage / runs smoother
just say no to those hot air suckers
Amsoil filters are better but having it in the grill is like having a straw
sent from my EVO 3D
theroofable
I have the black K&N filter. Makes the engine sound deeper and more throaty. Also has quiet whistle. It is very loud when first started and when the hood is up. I wouldnt worry about sucking in water unless you like to drive in lakes. I have driven in water up to the bumper and had no problems. Plus it made my gas milage go up 3mpgs.
ronj75
home
speedracerbubba
Ron, I do not believe the y-pipe intake provides any benefit to a traditional intake (either the stock box or a single tube design). If you really like the looks of it I don't see the harm since iirc, the KJ doesn't have a MAF sensor in the intake.
Chris_22
Beaumont,tx
you should try to box it off, otherwise you're pulling in hot air from the engine bay. which is actually hurting you
[/QUOTE]
NO performance gains from the Y piping, will just suck in more hot air which is not what you want
The computer will allow only so much and the stock set up provides plenty
Only thing you get with the CAI intake is more hot air and noise
I know
but thats about like putting a pair of socks down the front of your pants before a first date
when it comes time its not going to do ya much good :happy175:
theroofable
Run PVC pipe from your throttle body to under the drivers seat. That should give you the desired effect. Oh, dont forget to put a tooth brush in it for a filter.
Oh and I forgot, try not to fart too much or it will take away a few MPGs
JeepinJarhead03
Petersburg VA
X2
IMO, get the Y pipe, put some elbows on it , cut some ovals in the hood and mount the air filters so they stick up through the hood
or enclose the filters in resonator boxing and tube it up through the hood with 2 snorkel tophats.....
:whip:
if you want cold air, get cold air but you aren't going to find it under the hood
yep get one of those Y Pipe jobbers
they are well
JeepinJarhead03
Petersburg VA
i like my air coming right off the manifold
like i said, anyone wants to cut two holes in their hood I got about 20' of 8" stainless ill cut for ya lol...
Well since I already have two holes in my hood..................:happy175:
JeepinJarhead03
Petersburg VA
up and out then :p i'm sure you can either make or find cheaply some snork tophats :p
or if ya ask real nicely I'll build you some cowl scoops :p
JeepinJarhead03
Petersburg VA
Whats with the "Cement Slurry" :p
lemme guess the hood was up to wash off/out the engine, replace the tensioner, alternator and elec fan? :p
He found a mud hole the ATVs had been using to play in and had to see how fast he could go through for "photo" purposes
This was at the end of the day he finally checked it, and wash/replace nah he just drove it home that way :shrug:
