How Much Lift w/ OME?
Discussion in 'Lift Kit Discussion' started by TwoBobsKJ, Apr 12, 2011.
  1. TwoBobsKJ
    TwoBobsKJ Full Access Member
    2,637
    Jan 28, 2011
    Northern Ohio
    Posted this in the "Actual Lift Measurements..." sticky. Reposting here...
    OK guys, open for some feedback...
    Purchased Libby last fall (2010) cuz I've wanted a Jeep and the Libby passed the wife's requirements. :killit: No idea of the PO history except what came back from CarFax. Suspension shop that did alignment said the ball joints (upper and lower) look good. Had local dealer check the VIN for BJ recalls and they were done.
    No significant mods other than the few things I've done to it over the winter (hitch, cross bars, blah blah.) When poking around underneath while changing diff & TC oil and checking the brakes and suspension everything looks to be stock with no significant wear visually. Probably original shocks & springs but here are the height specs. Doesn't seem to have sagged as many others have...but I'm open to suggestions on lifts.
    Essentially stock '03 Renegade
    • 3.7L, 42RLE tranny
    • OEM Skids: Front diff, Transfer case, Fuel tank
    • Front tow hooks, OEM hitch, Light bar
    • 100,900 miles
    Measurements:
    Front L: 18 3/8 inches
    Front R: 18 1/2 inches
    Rear L: 18 1/2 inches
    Rear R: 18 1/2 inches
    Thinking basic OME 927/948 with Bilstein's but would I gain the advertised 2.5" height? Seems my Libby has settled only about 1/2 inch - so would OME get me to about 20" all around (1.5 inch lift)? Or would it go to 21" for a 2.5" lift?
    Look forward to your guidance... :party52:
  2. tommudd
    tommudd Moderator Staff Member Moderator
    17,773
    412
    You'll get at least 21-21.5 without anything else
  3. LetFreedomRing
    LetFreedomRing Full Access Member
    292
    Jul 1, 2010
    Pennsylvania
    Mine measured 18.5 all around before the lift. Put on 927/948 and Bilsteins and now its sitting at 21.5
  4. Dmut
    Dmut Full Access Member
    118
    May 22, 2009
    one of xUSSR republics
    Not trying to hijack a thread, but where can I find specs for Bilstein shocks? compressed, extended, travel, rod diameter? nothing on official site.
    I was kinda surprised, when I measured RSX17505. They have same compressed, extended, travel specs, as stock Mopar shocks. Rod in thicker, though.
    I'm looking for long travel forward shocks, and I'm not sure Bilstein is longer then stock.
  5. tommudd
    17,773
    412
    All front shocks are the same length none are longer
  6. TwoBobsKJ
    2,637
    Jan 28, 2011
    Northern Ohio
    Tom, LFR,
    Thanks for the input - the ride heights you indicated are better than I thought I'd get since my Libby hasn't sagged as much as others have. Me likes 21.5 inches! :gr_grin:
    So where should I pick up my OME/Bilstein's - JBA? RRO? Other places I haven't found yet...?
  7. tommudd
    17,773
    412
    JBA
    AllJs
    just say no to RRO
  8. Jo6pak
    Jo6pak Full Access Member
    2,934
    103
    Nov 10, 2010
    Left coast of WI
    Well said:happy175:
  9. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    I picked up my OME springs from www.sierraexpeditions.com
    And shocks from www.shockwarehouse.com
    They had the cheapest prices of where I looked.
  10. Dmut
    118
    May 22, 2009
    That s#cks... Stock forward shocks have only like 4-4.5" travel. I want to have at least 2" more, to feel good with 2.5-3" lift
    How those guys with 4"-6"-12" lift do run their KJs with stock articulation?
    Also, I regret I've put OME 927. With bullbar and winch it rides too soft. gonna change it to 790 or to some custom coil.
  11. DJSKJ
    DJSKJ Full Access Member
    149
    Oct 22, 2009
    California
    I put on the OME 927/948 one year ago and it sits at 21.25 today. Still have not upgraded the tires or A-arms yet.
    DJ
  12. TwoBobsKJ
    2,637
    Jan 28, 2011
    Northern Ohio
    Sweet!
    So what tires will the lifted Libby sitting at 21.5" handle without significant rub? 265/75/16's? Are 245's asking too much?
  13. Jo6pak
    2,934
    103
    Nov 10, 2010
    Left coast of WI
    Most guys are running 245/75-16, or 31.5" diameterwith a lift. Should have no issues there (may need to pound pinch welds.)
    265's may be a bit much without extra shims and clevis.
  14. tommudd
    17,773
    412
    Go 245-75s thats what most use and it works well, need more to do 265-75s plus a gear change to 4.10s
    I'm sitting over 23.50 and think its just right for 265-75s
    but if you want to go that route heres what it will look like
    [​IMG]
  15. jggv98
    jggv98 Full Access Member
    37
    Jul 13, 2007
    Monterrey
    is the same lift you get with OME Heavy Duty (927) and the OME Medium Duty (926) springs at the front?
    with stock bumper...
  16. tommudd
    17,773
    412
    You'll not get quite as much lift with the 926s
