Hood struts or supports?
Jake.Ski
Berlin, NJ.
What size do i need?
2002 jeep liberty sport.
Also do they have any sort of certain clips or anything?
TwoBobsKJ
Northern Ohio
RhinoPac 4366 times 2
Like JeepinJarhead03 said. Here's the link to RockAuto.com - Rhino's are $13.01/ea right now so $26 + shipping for a new pair.
Takes literally about 5 minutes to replace. A small flathead screwdriver to pull the clip away from the ball on the hood and fender, pull off the old one, then press the new one on. Just be sure to replace the new in the same orientation as the old (cylinder up, exposed piston down.)
If your hood supports are shot you might as well replace the rear glass lifts at the same time. Same process - the supports for the glass are slightly smaller.
