Ok..first post so bear w me... want bigger tires on my 03 liberty 4x4 ...want load range e and can't get unless at least a 245/70/16... well those rub...so was told by several people to put on spacers...so I did..now I am away from suspension but rubbing on fenders every time I hit a bump or when backing at an angle... do I have to lift or is there another solution ?
First Welcome
Second who ever told you to use spacers remove them then throw them at them since they are not your friends or trying to help
Where did these several people tell you that ?
Third, now measure from middle of the wheel to bottom of the flare on the left front and report back.
REASON BEING is these KJs have weak springs and most are sagged quite a bit , if sagged you can not run even 245-70-16s
At least you're somewhere now where folks will help you, not Fakebook land etc
