Heater issues?
gfunk_nz
New Zealand
I've just signed up and had a bit or a search through the forum, seems there's some pretty good info available.
I have a question about my 03 crd. A few months back I noticed the heater seemed to no longer be blowing really hot air. I'm not sure if it's an issue in the heater sytem as much as maybe a thermostat stuck open.
The engine temp gauge barely gets above about 1/4 I can't remember what it would get to prior to the lack of heating.
Reading through some of the info I see the viscous heater does a lot of the work in getting the heater to blow hot, if the thermostat is doing it's thing the the engine temp being around a 1/4 is correct, is there anything I can check on the viscous heater.
Any other suggestions?
gfunk_nz
New Zealand
It's got 92,000km on it now. The mileage is still about the same as hit has always been, if the gauge should be just under 1/2 which is what I would have expected I'm thinking it's got a stuck thermostat. Next job then is to get my self covered in coolant a check it out. To be honest I will probably have to search for that, I've done no in depth work on it as yet, just scheduled maintenance
journeyjim
mitchell south dakota from may through oct every y
I don't know about the amout of kilometers, but at 100.000 miles you change out the camshaft belt and usually the water pump and thermostat at that time.
gfunk_nz
New Zealand
I was actually planning on doing the belt, and water pump at 96,000km which is 60,000m. It's fairly low miles to be doing it but I want to keep it as per the service handbook, and I don't want to chance the belt snapping when it's done a good life and cost me a motor in the process.
