Originally posted on LOST KJS forum. Reposted here as a FYI:
I took the CRD to a local mechanic to do it's 30k mile service. The mechanic discovered that the heater connector was spewing fuel and that the tip of the connector had been burnt. He stopped work and gave me a call because it's a warranty issue. He said he tried to prime the system and that's when he discovered that is was spewing fuel. I guess he was checking it's integrity. He buttoned the thing back up and gave me the new fuel filter that he was going the replace to old one with.
So, I called the dealer. The dealer tells me that they will not fix the problem under warranty because I didn't have them do the work. Their claim is that my mechanic caused the problem and therefore it's not covered. Of course they said I could call DCX customer service, but they will tell me the same thing. However, I know that this is a known issue. Many folks here have reported the same thing. It may help me fight DCX if I had a list of folks that have experienced the same problem. I suspect that I'm going to have a fight on my hands and it might be helpful if I could provide a list of folks that are experiencing the same issue. This might be able to serve as proof that my mechanic did not cause this problem and that there is a problem with this part.
If memory serves, I recall some have reported this issue to the NHTSA. If so where do I find the complaints that have been register on this issue? This information might also help in proving it's a known issue and wasn't something caused by my mechanic.
Boy has this been a night to remember....
I hadn't got more than a block away from my mechanic's shop and the CRD stopped running right there in the middle of the road (heavy traffic too - joy!). Unfortunately, I had to coordinate a ride from a friend and the shop had long since closed by the time I got there to pick up the CRD. Anyway, I was stopped waiting for the light to change - so I didn't have any momentum to pull if off the road. Nobody would help to give me a push. I had to call the police to give me an assist. Then it took the tow truck and hour and 45 minutes to get to me. The tow truck guy hopped into vehicle and turned the key to put in neutral. He left the key on and within a minute smoke was rolling out from under the hood. I thought the thing was going to catch on fire. I jump in the vehicle, turned off the key, popped the hood, and pull the heater plug off (which was where all the smoke was coming from).
Boy I’m PO'ed… especially with my dealer’s response....
When it came time to buy, I was deciding between a F-150 and the CRD. Today I wish I went with the F-150.
