You have the wiring to the doors from the defrost switch?? I was thinking of adding heated mirrors but the wiring isn't there, i could add it, but with the amount of work involved i dont think its worth it yet.
atob what year do you have?
2004 columbia edition with power mirrors.
i noticed that the mirrors were fogging up in the bad weather this week and was wishing they had defrosters... hopefully this will solve the issue
Before buying anything i would pull a door panel apart and check the harness, it will be really obvious at the mirror plug, if you see two wires to the plug on the vehicle side of the harness that don't have mates on the plug from the mirror then your wired for it.... If not then you don't. And considering all the owners that said they didnt i wouldnt want to bet on it.
Okey Dokey.. Let us know what you find out!
I saw a KJ on a yard list for a nearby salvage yard a while back, it was a 04' limited and had heated mirrors, inquired and they told me $60 for the set if i removed them myself as the KJ was buried out in the yard. I was tempted but checked my 03' sport and the wiring isn't there.
ThunderbirdJunkie would make it switched with temperature
Out of laziness, that is.
If the wiring is not there, I'd just do a simply supply wire with in-line fuse and switch from an ignition side power supply to the mirror plug.
