Toymanjeep
I have an 06, 4wd.
Recently it has started making a bad bearing, grinding sound...coming from the console area. Got under it today to listen, sounds like the bell housing area. Does not seem to change with change of rpm, gear (auto) position, transfer case position. Sounds like a bad bearing, or something rubbing on a constant speed PTO shaft.
I'm on the road, towing it behind the Motorhome, I have AT&T sometime cell service, so may not respond to questions right away.
Edit...the noise I hear is sitting still, I can't say one way or another if it changes when moving.
