Full Power, No Start
starkravingmad
Ft. Lauderdale, FL
I've been lurking around here and you guys have been a wealth of knowledge. I've only had to take my KJ into the mechanic once because I didn't have the tools and they were out of my budget.
In any case, I'm in desperate need of advice. I swapped out my water pump today, ran the jeep for about 2 minutes to suck some coolant down and then tried firing her back up only minutes later.
The lights stayed on, the jeep made noise for about half a second and then nothing. I tried again and this time no noise whatsoever. Below is everything I've tried without success:
- Tightened battery terminal clamps
- pulled the WCM relay/fuse to reset the ignition stop light
- checked fuses
- swapped the ASD relay out
- swapped starter relay out
- swapped ignition relay out
- checked ignition switch pin
- checked battery
- disconnected battery for 20 min to reset WCM
Any ideas?
