Front windows
Discussion in 'KJ General Discussion' started by Disco95, Nov 10, 2019.
  1. Disco95
    Disco95 Full Access Member
    64
    Feb 6, 2018
    Secret Harbour WA
    G'day all,
    My front left glass (passengers here in oz) tilts forward when winding up. At the very bottom it's so bad the window stops till you physically tilt it back. I've replaced the mechs, with no difference. The other side looks and feels exactly the same, but the glass goes staight up and down without issue.
    Anyone else come across this?
    I should mention that it's a 2007 model and the windows are the type with tthe hole in the glass.
    Regards,
    Sean.
  2. kejobe
    kejobe Full Access Member
    364
    38
    Sep 5, 2016
    NE Ohio
    Check the tracks for the window. I'm not sure about these Jeeps but some vehicles have tracks that bolt in, and others that are welded from the factory. Either way, make sure they're there and not bent in way they shouldn't be. Also make sure the window is in the track in all positions. If the track is bent away from the glass, ir may still hold it in the track, but not firmly enough to keep it straight.
  3. Disco95
    64
    Feb 6, 2018
    Secret Harbour WA
    All looks normal inside, the tracks are bolted on and do not appear to be bent. I can't for the life of me see any difference between the drivers side and the passengers side. It has me stumped.
  4. Disco95
    64
    Feb 6, 2018
    Secret Harbour WA
    Update: looks like I figured out the problem, after not being able to look at this for a couple of weeks I jumped back in today. After pulling the rubbers from the tracks I pushed the button, and up the glass went, nice and straight. Gave the rubbers a spray with some silicone lube and wiped them down, refitted and, voila! Appears to be dry rubbers causing the issue.
    Thanks for the replies, I can't believe that no-one has had the problem before........
    Sean.
