Front driveshaft
83themule
Arizona
Should I be able to turn my front driveshaft when in 2wd? Should I be able to turn my front driveshaft when I have my transfer case in neutral? Thank you!
83themule
Arizona
Not if the front tires are on the ground. With the front wheels off the ground, you should be able to.
Thank you! for the response. I am new to the liberty model I have a rumbling, kind of clunking noise from the front-end and my friend was thinking the front axle was still locked because, the driveshaft would not turn in 2wd or in neutral with wheels on the ground. I was beginning to think I had a xfer case problem. How do I check to see if it is an axle or cv joint problem? Thank you! For your time
Start by checking the rear CV on the front driveshaft
More than likely the rear boot on the CV has gone mossing ( worn out ) and let dirt etc in the CV and its went bad
Easy to replace and costs less than 40 bucks if you do it yourself
Libertys do not have locking front hubs so of course everything turns all the time even when not in 4 Wheel Drive
Start by checking that , and then you can go from there
You can remove the front driveshaft and run without it to check if that may be it
83themule
Arizona
Thank you! I will check it out tomorrow.
jeepop
Middle Tenneesee
You only need to jack up the drivers side front wheel to be able to turn the prop shaft. You can then shift in and out of 4 high to stop the shaft from turning as you remove bolts. Most the videos online say its held in by 8 mm, but I started to strip a bolt with 8 mm and got better fit from my craftsman 5/16
