Front Driveshaft?
fishin'liberty
Saint Joseph, MI
So I originally thought my passenger side cv was going bad, but after further inspection today there is very minimal play. There is a small leak from where it would connect with the intermediate shaft, could this just be a seal issue? Also I checked my front drive shaft. It is able to spin in about 180 degree motion. I was wondering if this is normal or if it is time to replace it? Thank you in advance for all your help.
yellocoyote
NW Chicagoland
Your leak sounds like it's an axle seal - cheap to replace. Easy too, once you get the CV joint removed.
A mild bit of play in the front driveshaft is okay, but 180-degrees sounds quite excessive!!
fishin'liberty
Saint Joseph, MI
found the axle seal on moparpartsamerica.com. whats the best way to check the front driveshaft for any problems? No play in it at either joint, but when i grab the middle I can spin it. No movement when trying to shake it.
rockymountain
Spencerville, IN
The front driveshaft should be solid with no play anywhere. It may wiggle but rotational play is a sign its done. Did you check the CV at the transfer case? make sure the boot is still there and no grease is painted on the bottom of the jeep. I don't' understand how you can have no play at either joint but you can spin the shaft. Are the tires off the ground?
