DJSKJ
So I took the Libby to a Jiffy Lube today for a ****** flush. I told them the specifics for using only ATF+4 fluid. The guy said no problem and they put an additive in the fluid they use in order to make it compliant with specs. I am a skeptic, but I have to believe being a nation wide chain they know what they are doing (even though they always over torque the filter and drain plug). What say all the peeps out there? Is this any good or did I get hosed? I did the same thing at a Juffy Lube about 25k miles ago and also put on a new filter then as well. Have not had any problems and it is at 82,500 miles now.
DJ
DJ
