Hello,
I just reinstalled the 42RLE transmission on my 2005 KJ Liberty 3.7.
This transmission and the converter were completely reconditioned by a specialized company.
I also changed the oil cooler and the hoses that go to the cooler.
I filled the transmission with ATF+4 as indicated in the workshop manual.
I tested it by operating the selector lever while cold, then checking the level each time, and then checking the level again while hot after driving several kilometers.
I was at 8 liters of ATF+4 and the KJ was idling in the garage. I was about to check the level again when suddenly the engine seemed to stall, followed immediately by a noise like a balloon deflating, and the engine returned to its normal speed.
I looked under the vehicle and saw that the gasket paste on the crankcase had failed, and oil was leaking through the gasket.
I immediately turned off the engine.
There was clearly too much pressure in the crankcase; the oil was hot, around 60°C, and I couldn't keep my hand on it.
However, the oil pipes and the cooler were barely warm.
I checked that the circuit was working properly, and there is oil in the radiator.
The rubber hose on top of the gearbox does not appear to be blocked.
What could have happened and where did the problem come from?
I don't have a DRB3 to diagnose the gearbox.
Thank you.
Thank you.
