So I just found out this past weekend that my 2003 KJ built in May of 2003 actually has a 45RFE ****** (Backwards angled cross member, TCM mounted on passenger fender, 15 bolt ****** pan). I was elated to say the least for many reasons-
I've now owned an 02 Ram 1500 4.7, 04 Ram 2500 HEMI, and 03 Dakota CrewCab 4.7 all that had the 45 or 545RFE ******. I've plowed commercially with both the Ram 2500 and Dakota putting this ****** through it paces. I never once had a problem with it and know for a fact that its built for a much heavier, larger, and powerful vehicle.
Downsides- I hate the gear spacing when placed in a Dakota/Ram and the programming leaves much to be desired.
Anyways, I belong to other forums for the trucks and back in 2007ish guys were realizing that you could Flash the TCM of trucks to make the 45RFE to have the second overdrive of the 545RFE lowering highway RPM's by about 300RPM. Guys with Ram's and Dakota's were netting 2-3mpg on the highway with this mod. When I realized that the Liberty had this ****** I knew it could be done.
Thankfully my company is licensed by GM/Chrysler/Ford to do warranty work on our fleet meaning I have access to all factory flashes and TSB's, etc. Here is what I found - TSB# 18-025-01
"THIS REVISION TO THE TCM SOFTWARE ADDRESSES THE ABOVE SHIFT QUALITY CONDITIONS FOR ALL VEHICLES AND ADDS A FINAL GEAR RATIO TO THE 99 & 2000 GRAND CHEROKEE TRANSMISSION ONLY"
Fact is, they all use the same TCM. After 2003 the transmission programming was integrated with the ECM, any years before that using the 45RFE ****** can have this flash done.
I plan on bringing my Jeep in this week to work and flashing the programming in.
Just throught I'd post this info up in case you guys weren't aware of this. I know that my Jeep will benefit from this as a lot of our roads are long and higher speed (55mph speed limits).
