kb0nly
Deleted...
Seems the NGK's wear pretty fast, though i believe they are just standard copper's right? The platinums should wear a lot slower. I also noticed a boost in mileage and can't complain about that!
Easy except for one plug... We all know which one that is.... lol
Got some nice weather finally to give the KJ some love... New plugs!
Original NGK plugs with 53k on them, they were out to .060-.065, replaced with new Autolite Platinums, AP3923. Idle is smoother, and it even starts quicker if you know what i mean, shorter crank before hearing it fire.
I found it interesting how they all wore differently... Some have an angle to them, some are just flat, some are just rounded. As you can see in the pics its been needed for a while, just couldn't get it done with all the snowy and rainy days and no garage.
Damn were they in there tight, yes the engine was cold. And that rear passenger side plug is a PITA, but it went ok. Just had to borrow a swivel from a friend, mine broke a couple weeks ago and forgot to get a new one. Also got to break in the new air compressor to blow the dirt off the engine and then out of the plug holes before plug removal.
The AP3923 are platinum plugs for the 02-04 KJ. The 5224 series are from 05-07. But either work from what I've read. I just went with the 5224 because they are for my year and they are available in double platinumJust curious but did you get the right plugs? the Autolite Platinums for the KJ should have been the AP5224 series.. Gap at .040
Probably the same crap as the E3 plugs. Stay awayAh didn't know there was a difference from the 02-04 and 05-07 interesting.. I'll keep that in mind... Also has anyone heard of Pulstar Spark Plugs? you get two for 24.95 at Autozone.. They claim to be 10X stronger than a regular spark plug.. I dunno..
That is caused by how the plug sat in the combustion chamber.Indexing the plugs will show the exact same wear for each cylinder(if no misfires or mechanical damage is done) when you change them.Same here... You can see two of them are worn with a slant to the tip, one side is gone all the way down to the insulator and the other side is still fairly high. And then most of the others are just flat across or rounded.
