Factory Build Sheet
Sometimes I see questions like: what kind of transmission do I have, and what gear ratio do I have, did my Jeep come with the tow package, and when was my Jeep built?
Questions about what factory options your Jeep came with can be answered by downloading the build sheet for your vehicle. All you need is your VIN number.
http://fcacommunity.force.com/RAM/s/equipment-listing
The link above should work for any FCA (now Stellantis) vehicle from the last 20 years or so.
jeepchic79
Northern Kentucky
I just added my vin to my mopar owner's and it told me everything. I sadly got the 4 speed with od in my 06
The six speed manual would have been awesome. They did make a few KK’s with that in 08 but then discontinued it. I have the 4 speed automatic also.
jeepchic79
Northern Kentucky
I'm sure it's been asked but wouldn't a 6 speed interchange? Since we have the 3.7 or would it be a mess of work .
It’s not the physical fitment that’s the issue necessarily. I’m sure that could be done. It is the electronics that would make it impossible without some kind of professional tune for lots of $$$. Or at least that would be the case on the KK.
Worked on all 3 of mine,
had done it years ago, but thought I'd run them again
I just ran my 08 through it and it worked. I experimented a bit and found out it IS case sensitive, and will not work if you use any lower case letters. Hope this helps!
David13
Central Utah Rocky Mtns
That was the first thing I tried and it worked. But I thought I might have had a digit or letter error also.
dc
Fired
Check if you have a pdf handler in your browser. I initially had trouble but but messed with a setting and it popped right up.
