Engine stalls! Need help!
catdogbus
richmond va
it only happens when backing up now. it has a new transmission, new rear end (just about, rims are oringal). new raditor, new spark plugs (put in monday) and new power steering everything and all new fluids in everything.. when i back up sometimes (and mainly if im turning hard to eirther side) the engine will shake and stall and i have to crank it right back up and then it drives find? i cant find out whats wrong with it please help me! sorry for the typos
ftaa
canada
since you dont know what it is you probably need one ... it tells the computer when to shift and how to shift... this could be the issue
catdogbus
richmond va
they shop clearned the codes on monday. and wouldn't the shop have done a re-learn when they put in the new trans?
catdogbus
richmond va
the codes were the spark plugs because one was misfiring so got them all replaced and then an O2 sensor was bad and got it replaced
ftaa
canada
a misfire is normally the coil pack not the plug.
ftaa
canada
also if the o2 sensor wasn't the same as the other 3 yer gonna have problems with it too ... i believe oem ones are NGK if you have a bosch and 3 ngk yer gonna have trouble soon
ftaa
canada
well ask about if they learned the transmission if they did then you need a copil pac probably but it could be the wiring to the coilpack and not the pack itself.
catdogbus
richmond va
they put all new plugs in because i asked them too since i am about to hit 100,000, and and ill call him tonight (hes a family friend) and ask.
ftaa
canada
do that then ... if the misfire is on the same cylinder take the coil pac off and put it on a different cylinder it should then jump there ... easy way to test without putting a pac in
