Dorman Trans Pan with Temp Probe Bung
Anyone want this thing? Had it installed since 2017 or so and its not been off since. Bolts were torqued to factory spec, so it shouldnt be dimpled.
The **** is welded in on the passenger side and is kinda close to the cat. I used some spark plug boot protectors to shield the wire from the heat, worked fine till just recently when I replaced the pan with a PML unit.
Make me an offer.
