67Customs
I am in the middle of doing my 30K service to my 2005 KJ. I have already completed everything but the rear differential fluid change.
Now, I have searched Jeep KJ and LOST KJ up and down, but I can't find a definite answer to my first question. On the rear differential, what is the proper fluid level? 1/2" below the fill hole, or fluid running out of the fill hole?
I know the front is 1/2" below the fill hole. The Owners Manual is clear about that. What it isn't clear about is the rear. It has "Rear" in the heading, but only talks about the changing of the front.
My second question is about the front differential. Before I changed the fluid, when I put the KJ in 4 full-time, I would feel a little extra shake in the steering wheel upon slighly heavy acceleration. Nothing major, so I didn't worry about it. I thought it was a Jeep 4-wheel drive thing. After changing the fluid, I feel the shake more. Nothing horrible, but I am a little concerned now that it has gotten worse. Why would changing the fluid accentuate this feeling and since it has accentuated it, has the new fluid uncovered a problem? I filled it to 1/2" below the fill hole and used Mobil 1 75-140 as I do some towing occasionaly and use 4 full-time fairly often. What might be the problem or is this something common with the Liberty 4-wheel drive? I sort of feel that it insn't enough of a shake to be a problem and that I am overworrying myself, but I would like to make sure.
BTW, I canged the fluid in the front diff, but had not changed the t-case nor the read diff when I felt this problem.
Just a little rant, I find it extremely difficult to search anything on LOST. You can't really refine your searches enough. I use connector words, but I still get too much. Also, you can't search post topics, only post bodies. AND, when you try to back up to the search page, it has either expired or gives you another message. I know I can aleviate that problem by opening each searched thread in a new window, but that is not the way I serf. When I search on LOST I feel a little, well, lost. /rant.
