offrovering
before I tackle this stuff on the jeep, couple questions.
from reading here it looks like I have most covered, but just thought I would gather input.
1) drain front diff, simple drain and refill via plugs - 75w140
2) drain rear diff, drain and remove front casing, clean, replace with liquid gasket maker and refill - 75w140
3) drain transmission, drop pan and clean, replace filter(s), replace pan with mopar gasket, refill via dipstick - ATF+4
4) transfercase, simple drain and refill via plugs - ATF+4
mainly questioning ****** and transfer case, do I need to cycle the gears while running for ******? transfercase, just fill until small bead is dripping?
