kokali22
On a 2002 sport... The auto transmission cooler, Is it intergrated into the radiator OR Is it an external/auxiliary unit and sits infront of the radiator right next to the drivers side headlight?
I think on a 2002 it is integrated into the radiator. If you see a small radiator on the driver's side that is probably the power steering cooler. Just pop the hood and follow the tubing and see if it goes to the power steering reservoir.kokali22 said:another question? How do I figure out which transmission I have? Like maybe some place to run the vin and check it out and what not?
jeepjeepster said:A 2002 liberty came with the power steering cooler stock. It had an integrated cooler on ALL models and got an aux cooler with the towing pack(or offroad pack, maybe).. O
Marlon_JBT said:kokali22 said:another question? How do I figure out which transmission I have? Like maybe some place to run the vin and check it out and what not?
Open the hood.
Look over to the left, by the coolant bottle.
If you see a computer mounted on your passenger side fender, you have the 45RFE. SInce you have a 2002, you definitely have the 45RFE.
