Once I replace these things will I uncover deeper problems? I fear that replacing the thermostat will cause the engine to overheat. Right now the only problem I have is no heat and I'm kind of thinking maybe I should leave things the way they are for the time being. What would be the consequences of leaving it the way it is? I bought this jeep dirt cheap so I'm sure there are other underlying issues. There is an oil leak of unknown origin which leads me to believe that perhaps I may have some head problems that would show up after replacing the thermostat. What would you do in this situation?
The consequences of leaving it? Would be having to buy a new engine lol.
Our engines are NOT fans of running without coolant. All it takes is one good overheat to throw a rocker, drop a valve and Crack a piston.
What would I do I this situation? I would stop driving the Jeep without coolant in the radiator lol.. even if it's a DD, the problem has got to be fixed asap, or you'll be posting about a much more expensive problem shortly..
Better to go a few days without your DD, than to lose it forever.. no?
That being said, any problem is fixable. If you want to look for your oil leak, we can help to figure that out as well.
You'd have much scarier issues if your heads were going bad.. You say you're leaking oil, but if your heads were bad.. even with the leak, your oil level would Rise. Because there would be coolant being added at all times, thus raising the oil and dropping the coolant level.
Also, leaking oil isn't a sure sign of bad heads.. if anything oil consumption would be. I mean, I'm pretty sure that 99% of the liberties on the road have had to change their valve cover gaskets, so that would be the first place I checked for the leak.
If you want to know for sure that your heads are good or bad, check your oil dipstick and look at the bottom for milky fluid. You can also drain some of the oil from the pan to see what it looks like. If the Jeep has been sitting still, the oil in the pan will float on top of the coolant and when you drain some out....if there's coolant, it should be the first thing to come out.
Don't listen to your temperature gauge over diagnostics.. your gauge is a liar lol. Especially if it does
not change from running your radiator dry.
