clunk clunk
telefunkin
p.E.I.
Thanks for all the suggestions guys, I can't figure out what's causing it. It's due for a oil change so I think I'll take it in to be looked at. I still have warranty coverage so hopefully I can get it figured out while I'm still covered. On a side note, I realized today that it is only doing it on dry pavement. We got quite a bit of snow on the roads here and it hasn't done it at all since the snow hit.
Ok, I was lied to. I went out and jacked up the front and turned the wheel/tire and the CV shaft turned. Why didn't Jeep put in a autolocking hub? WTfudge? More gas mileage, less wear and tear. What were they thinking?
The strongest/least complex setup and like stated little to no effect on mpg if you keep up with the diff fluid changes with the correct for your application gear oil.
If I wasn't using CTM u-joints on the front axles in my HP44 I would use drive slugs(instead of manual locking hubs,which is now my front axle weak point) which is just the same as a stock KJ uses.
candpliberty
Las Vegas, Nevada
Sigh. :( That was the last time I listen to a salesman at a stealership. peepwall.gif My guard is up when I walk on a showroom floor, more than ever before! I'll read spec sheets with a different mindset! Thanks for setting me straight, everyone!
osufans
Central Ohio
i notice a bit of brake noise every now and then...mostly from the rear...maybe this is what you are referring to?
is that sound normal btw?
the pads look like they have a fair amount of material left on them, i'm not too worried about it just yet, but will definitely be doing brakes in a few months anyways, so i was gonna check it out then.
moparman
Baltimore, MD
What about normal rear end gear lash and the auto trans shifting up as you let off the gas? I get that. Chrysler rear ends have always had a lot of gear lash. (play)
rockymountain
Spencerville, IN
It is the rear end. Sometimes but very rarely (if this is bad let me know) I throw it up into Neutral when coming to a stop at a light. I do this at under 20 MPH while braking. It STILL CLUNKS the exact same way as if it is in drive. I could be wrong, but I say "don't worry about it". Like I said, my '03 did it too. Maybe it is just a certain driving style that puts a "spotlight" on it.
I have on open 8.25 btw.
sharpy
maine
is seems like also the ****** will up shift from 1st to 2nd when not under any load....coasting per say....and cause a littel clunk.
Robsama
Connecticut, USA
I get the same thing on mine from time to time as well. I thought at first maybe it had to do with my ****** fluid. I'm about due for a change and was hoping to put it off until it was a bit warmer so I could do it myself.
Here's when I get it. I'll be driving at a normal speed, say 40MPH. I see a red light ahead so just coast up to it but if it turns green before I get there (and I've slowed to say about 15-20MPH) and I hit the gas *CLUNK* from the rear end. It doesn't happen all the time and I haven't tried to recreate it yet. Maybe I'll give it a shot this weekend to see if I can make it happen under a specific driving condition.
