Changing Rear Differential FLuid
ptsb5a
Northern Alberta, Canada
Thanks for the correction. It worked on Ford 9"s and Mopar Danas when I was looking for one for my big block 70 Chevelle. Has the technology changed that much? There used to be clutch packs between the axles. Where is the limited slip mech (clutch pack) hiding now?
Under(or beside,depending on how you look at it)) the side gears.
