Your KJ Liberty has a Dana 30a in the front - most Dana 30 that came in other vehicles are different because they have a solid front axle. The Liberty does not have a solid front axle because it has independent front suspension. One of the other big differences between the 30a and the regular 30 is that the 30a has an aluminum housing, the regular 30 has a cast iron housing, the 30a is therefore weaker than the already weak 30. Probably no need talking more about the Dana 30a here anyway because it doesn't need a skid plate of its own because it's already well protected by the front skid on your Liberty. There may however be a benefit to installing a heavy duty cast iron (or aluminum) diff cover on your 30a because it will strengthen the housing and reduce the likelihood of it cracking due to internal forces or twisting of the housing that might happen when rock crawling etc.
The KJ came with one of two rear axles / diffs. Some came with a Chrysler 8.25 and some came with a Dana 35 - if you don't know what yours has that would be the first thing to figure out. They are completely different - different housing, different cover, different internals, different bolt pattern. That link I provided shows photos of both - easiest way to identify what you have is that the Chrysler 8.25 has a flat bottom on the flange of the housing, the Dana 35 is more rounded. The Chrysler 8.25 is considered the better diff because it is bigger and heavier duty. If you Google "Chrysler 8.25 vs Dana 35" you'll find a bunch of videos comparing the 2.
