It's possible,how much money you willing to spend is the question.To go anything past 4" the right way and still be 100% functional is big $$$$ with the IFS,then it get's cheaper to do a SFA swap.The biggest thing is you are still limited with the D30A,a aluminum housing and can not go lower then 4.10 gears,any tire above a 32" size wull kill the diff and really suck the gas from being under powered so anything over a 4" lift is pointless on a KJ unless you do a SFA swap to gear correctly.
X2
Gears are the biggest problem well tied for first with the alum. front diff
Toy's can regear to as low as 4.88 I think in the stock diff's maybe lower and their diff's can handle 33's easy and even be pushed with 35's
I would not bother with anything over a 245/75 16 for a KJ on stock diff's
if I feel the need to go bigger I would just go SFA
I would get a dana 30 from any coil sprung Jeep and keep the stock rear
Then I would lift it to handle 33's with room to spare
regear to 4.88 maybe 4.56 up grade the rear shafts and Detroits on both ends
could be done with a little less work if you find a "donor" Jeep with a 30/44 combo and pull the diffs then they ,the diffs would be ready for TJ suspension
I would then get a TJ long arm kit and not use those springs but get the ones that would work for a KJ
I would then build sub-frames for the front and rear mounting points
Let me say this
If I had the time and a shop with the right tools I think I could design a semi bolt on SFA kit for the KJ using TJ axles and suspension
