About to Frankenlift, got some questions
LiberatorBB
Seattle, WA
I'm gonna be installing my Frankenlift and JBA ucas this week. It came with rear bumpstops, but not front ones.
Is a teraflex front bump stop something I should also buy, or is the stock one long enough?
Also, I bought some Cragar soft 8s that are 16x8 with 5" backspace. I plan on putting 245-75-16 duratracs on them. Any idea if I'll need to pound the pinch weld?
Thanks in advance! :worthy:
Brandon
Is a teraflex front bump stop something I should also buy, or is the stock one long enough? GO WITH TERAFLEX ONES
Also, I bought some Cragar soft 8s that are 16x8 with 5" backspace. I plan on putting 245-75-16 duratracs on them. Any idea if I'll need to pound the pinch weld? YES HEAT THE PLASTIC UP AND BEND OUT OF THE WAY, POUND OVER AND MELT THE PLASTIC BACK OVER
Brandon
hope that helps
Luke
Interloper
Bancroft, Canada
Common consensus is yes... All J's says not needed :shrug:
If you see yourself pushing the suspension to it's max frequently then they will help you to not over compress the shocks ... personally I can't imagine the coils ever compressing that much they are so freakin' stiff. :D
I can see them compressing that much
takes some to do it but its possible
LiberatorBB
Seattle, WA
Alright, I purchased the bump stops from JeepinbyAl. I'm getting the lift before I can afford the tires, so I've got a few weekends before I gotta pound the pinch welds. I have to find a heat gun somewhere. Thanks for your help guys!
