4:10 gears
J-Thompson
just south of doucheville
I am not sure what it is you are looking at there
You do NOT want a locker for the front unless
you are spending the money for an ARB
Go to the 4wd Hardware web site and find
the Detroit True Track for a TJ Dana 30
I don't know 100% if this is the right 1
to fit a KJ but it will show you what you want
03 JEEP KJ BIG BLUE
Perham MN
ok so about 1100 more for the lockers but wont be paying to have them locked later. sounds like a pretty big no brainer. lol thanks guys ill let you know how it goes. im hoping to have her in the shop begining or middle of jan.
J-Thompson
I can promise you this
A locked Jeep will go places that an open Jeep
can only dream of
If I were to tell you ,or most any one who has an open
TJ on 33's, that your locked KJ could go further you
and they would probably doubt me
but pick the right line and you can
can only dream of
I can vouch for this.When I had the DTT/ARB combo with 265/75's I could run circles around TJ's with 33"/34" tires that were open/open.
2006 KJ
jamestown PA
i just regeared to 4.10's with a detroit locker in the rear.
i bought a used front diff with 4.10's already in it (from a 4cyl liberty) and just unbolted the stock one and reinstalled the used one with 4.10's and the front was done. the whole used front diff was $300 delivered from a local junk yard.
the rear was a little bit more.. and i had a rear end guy do the install for the rear gears, rear install kit, and detroit locker.
city mpg's stayed the same at about 14... highway mpg's went from 14-15 to 17-18.
running 265/75/16's on steel wheels with a HEAVY KJ (6 speed)
it's SOOOO nice not having to down shift to 5th or 4th on the highway for hills or just cruising 60mph around towns... just set the cruise and the KJ is thrilled. HUGE difference going from my 3.55's to 4.10s
oh and listen to everyone saying not to buy a lunch box locker. i had an aussie locker in the rear before switching to the detroit. the aussie locker was a lot better then no locker... but not even remotely close to the quality of the detroit.
i bet i could burn both back tires through 4 gears if i put on a set of stock sized tires with stock alum. wheels :)
03 JEEP KJ BIG BLUE
Perham MN
sounds like i better lock it for sure while its all being taken apart. im going to see where my budget is after x mas and hopefully get it down there and done really soon
