4.10 gears from 4 cylinder
Just make sure they are the right ones, look for numbers on the springs, you want 927s for front and 948 for rear
If not you may end up with 925s which only give about an inch of lift
05KJBaj
Perfect thank you
05KJBaj
So I went back today and they are 927, I also found one liberty with Koni struts, are they good or should I stick with the ome. Also is 200$ a good price for an arb bumper with a little bit of surface rust and a busted blinker glass?
sleazy rider
SE Michigan
Well, retail on an ARB is in the $1000 range. I’d grab it, given the opportunity.
Go with OME " shocks" , way better than Koni
And grab that ARB bumper, cheap price for sure
Even if it is not the right one for your year you can resell for a profit
05KJBaj
Thanks i'll do that, also I grabbed some crown bump stops. I checked all my bump stops and I was missing one front one, and the 2 back ones !! So that explains the massive rubbing, after installation I did some testing and there is almost 0 rubbing now, I also did the full flex in the back and the wheel doesn't touch the fender. For the spacers, I cannot remove them, they have been put there so that the wheels I have can fit, you cannot mount them on the stock spoke they are not the right size.
05KJBaj
Hey Tom, I came across an old thread of yours from 2009 when you cut the rear bumper. You had an arb front bumper, looked really good ! Did you paint it yourself ? The one I found in the junkyard is the same model, do I need to put an older grille to make it fit to my 05?
If you found an early model ( 02-04 ) lots more to change than just the grill
would have to change grill, radiator support, flares , etc, if not would look really bad
05KJBaj
Oh okay, sadly the one i found is an early model 02-04. It really looked good on your 04 ! Do you still have it on?
No, Had it on for about 8-9 years, it killed many dear, a Toyota Camry and GMC pickup, and hardly a scratch
Then decided to get a new bumper from Rock Lizard for a great deal so sold it ( wish I would of kept it , would love to have another one )
I kept changing things over the years as far as different lifts, ( testing them and upgrading for more lift ) bumpers etc to keep it top of the list
But sold it for 3 times what I paid for it !!!! ;)
05KJBaj
How's it going tom ? Tomorrow I am going to pickup my shocks and springs. Last time I went I only found ome 947 for the rear, are they the same height as 948 ?
