4.10 gears from 4 cylinder
05KJBaj
Hi everyone, I have a 05 liberty with 31" Grabbers and I am about to buy a set of differentials from a 4 cylinder liberty to have the 4.10 gears. Is it directly bolt on or what is the easiest way to install ? I think i'll just swap the diffs instead of opening and swapping the gears. Will the new 4.10 gears have the same limited slip in the rear ?
Some do, most do not as far as the trash loc goes
Also direct swap , whole diff, would never open it up and just swap gears
Disconnect the ebrake cables, remove calipers and leave brake lines attached and just hang them up to frame, remove shocks, whole tri link bracket etc
then pop in new diff , easy
Front is just as easy , two bolts into the frame ( crossmember ) cut them off since they are in backwards to remove easily, disconnect the mounts and drop out and replace
Easy project for an afternoon, ( well not the whole afternoon LOL )
What lift are you running ?
and how much?
duderz7
Weiser, ID
Couldn't there be some abs differences depending on year of donor rear? Even if the "new" rear end doesn't have trak loc it's likely not worth swapping. If you were going to take it apart to upgrade might as well look at a better locker at that point.
05KJBaj
and how much?
Thanks for the clear answer and explanation
Right now I am only running a spring lift but soon i'll buy an ironman kit.
I didn't intend on buying lockers since i want to keep it cheap, i will get both diffs for under 200$ (200 for the set of 2 diffs) so i was counting on the track lock, i like it for my use (90% sand desert in uae)
05KJBaj
and how much?
How'd i know if it is equipped with the tracklock?
05 is same as 02-04s , same speedo etc, 06/07 is where they screwed everything up
Spin one axle if both turn the same you have trash loc, if they turn differently , you do not
Hopefully the ones you find do not, since most people do not change the fluids like they should and the trash locs if so equipped wear out fast
plus they call them trash locs for a very good reason
05KJBaj
is it really that bad ? It's really been helping in the sand
duderz7
Weiser, ID
My "trash loc" seems to be working well enough, but if I was going to do diff work I'd put something better in for certain. Nothing like a true locking axle, it's almost like magic, but not.
Tom, did they not make 4 bangers after '05 meaning it's not something he'd want to pay attention to? Asking because I honestly don't know. Not trying to be a smart ***.
They produced KJs with gas 4 cylinders from 02-05, but in 05 they must be more rare than hens teeth, I've never ran across any of them when hunting for 4.10 gears
My 03 had a trash loc in it when I bought it, worked great as well
of course the original owners changed diff fluids with proper additive religiously according to the paper work they gave me
05KJBaj
About the additives and fluid, I am running 75w140 full synthetic for limited slip, what did you use when you still had trac lok and is what i am using good?
05KJBaj
Mannol 75w140 Maxpower 4x4
I never , ever use synthetic in any diff
plain old dino stays on so much better
I use the Mopar additive for trash locs
Bought out a former Jeep Tech years ago , had a ton of Liberty parts and included was 24 bottles of the stuff LOL
Ive been reading a lot of people saying NOT to use syn diff fluid. Its all Ive ever used, why the recommendation against it?
Many of the gear manufactures have always stated not to use synthetic as it does not stay on the gears as well, slings off easily
05KJBaj
Okay i'll try to find conventional oil for the next change. What do you think is the best available shock for high speed offroading ? I've found some used ome in my local junkyard today and also a stock shock with king spring so i was thinking of mixing these two
05KJBaj
Btw Tom thanks a lot, you are really carrying this website and i've seen you answer in every thread i came across since i have my liberty
Stock shocks are pure junk from day one
USED OME ? I wouldn't, you never know how they have been used and abused , unless they look brand new
King springs are good as long as they are not stacked ( worn out ) and for the Liberty
05KJBaj
The ome strut didn't look too bad, but the spring with it was a little rusty and cracked, that's why i wanted to use the king springs which looked great too
King springs are great from what I have always been told by the Aussie guys
So if the front OME "shock" looks good then there ya go
