If you're not familar with fixing automobiles nor do you have the equipment, how much would you pay for a 30k maintenance schedule? My local dealer has a filer which says
1. Change oil and oil filter
2. Major lubrication
3. Check Fluids & add if necessary
4. Replace:
(a) spark plugs if necessary (piat plug additional)
(b) air filter
(c) fuel filter
(d) pvc valve if necessary
(e) breather element
(f) roter & cap (ignition wires additional)
(g) add fuel injection cleaner to gas tank
(h) add oil additive to crank case
(i) anti-freeze (2 gal)
5. service & clean battery terminals
6. Replace belts
7. Pressure check cooling systems:
(a) check hoses, tighten loose connections
(b) check anti-freeze
8. repack wheel bears (except jeep)
9. check front end for wear
10. rotate & balance tires
11. check brakes and adjust
12. check alignment
13. check tire pressure
14. service transmission:
(a) replace filter & fluid (special filters additional)
15. replace axle fluid, front and rear
16. replace transfer case fluid
17. DRB test
18. road test vechicle
.....all for the price of $749.95
I'm near my 30k mark and wanted to know how much should someone pay for maintenace? I live in an urban area and I would assume prices maybe slightly higher than rural prices. but who knows..
4. Replace:
(b) air filter
(c) fuel filter
6. Replace belts
12. check alignment
17. DRB test
