- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 40
Actually it will since you have different gear ratios in the front diff as what is in the rear diff.10 or 20 feet,no big deal but binding will occure even driving in a straight line.Going in 4LO on a driveway (paved) is fine if you don't turn. Transfercase won't know the difference.
Actually, just about every time I wash the KJ, I pop in 4LO to coast in the garage just to keep the shifter from locking up.
As far as no love for a auto trans you do not know what your missing,besides the 42RLE,most auto's nowday's are 10 times the trans of even the best manuals offered today.
Even comparing stock to stock my '02 Kj with the 45RFE has twice the pulling power and torque multiplication as your 6 speed manual.In addition to the mechanical gearing most do not figure in the 2.5:1 reduction the torque converter gives in addition to the mechanical gearing and why auto's are geared higher then manuals(internal trans gears).
If that doesn't make you think maybe look at new 3/4 ton and 1 ton pickups.One only has a manual available and if you take it you also must take a 200lbs-ft of torque loss as the trans can not handle 800lbs-ft+ of torque.
