2nd Battery Install
w00dr0w
Corvallis
Has anyone done a decent writeup or YouTube video of installing a second, deep cycle battery in the KJ? I have this crazy idea of having a second battery and a power inverter for running some 110VAC gear while camping. Primarily some led lighting, a small boom box, charging cameras, phones, laptops and possibly running a small fridge. Has anyone done anything like this? I am not sure where I would put a second battery to begin with - not alot of extra room under the hood...
dhula
West Oz
I usually use this --> Waeco Coolpower and plonk it in the back with all my other stuff. problem with that is it takes up space that could be better used for other stuff.
I was thinking that I might be able to fit something more permanent under the passenger seat as there is a fair bit of room there but I think it would definitely need to be a AGM type battery (similar to the Optima battery that Jeep put in the KJ Deso). I could always get really gucci and use a Li type battery but it can get pretty expensive setting it all up to work properly.
I do like the ease of the Waeco battery pack and the fact I did '2/5 of 5/8 of FA' to fit it to the KJ and make it work so not sure yet which way I'll go.
That battery pack looks great.
Not sure if anyone has put a spare battery in the KJ but I am interested to see.......
That is a lot of demands especially when you state "small fridge"
I hope you mean a 12 v camp cooler....
Last time I was camping for 5 days, had my AGM 500watt inverter/jumper power box for electronics charger:
59020[/ATTACH]"]
And also took a separate group 34/78 battery with separate battery clamp converter for the cooler.
The 2nd battery was then charged up overnight with a c-tek 4.3 amp charger from the power box.
If in the sun, a good solar panel can keep the battery up in the daytime as well.
For a true deep cycle battery an Odyssey with tons of juice is the only way to go!
59022[/ATTACH]"]
The power box needed charging daily, used the Jeep to charge it plugged into an accessory socket with jeep running for 30 minutes.
Here also is a link re adding a Dual Battery set-up. ..
http://www.jeepkj.com/forum/f196/dual-battery-system-where-put-2nd-batt-49514/
J33Pfan
NY
There's no room for nothing!!!
Honda Generator is your friend
renegade 04
Albany New York
I was actually thinking of relocating the battery to under the back of the jeep in the future to free up space under the hood for other fun stuff. I am thinking of putting it in the drivers rear wheel well area.
w00dr0w
Corvallis
That is a nice battery pack... If I can't find a good way to mount a second battery I might get one similar - I will definitely consider that one!
w00dr0w
Corvallis
Yeah that is what I meant lol... I do like that Odyssey battery though. The Optimas are overrated :gr_grin:
