2006 jeep liberty help
rockyboy99
Shippensburg
Hello I am very new to this and I would like to put a lift on my jeep and a light bar, are there any lift kits that are under 500 and that have good reviews and light bars, any specific brands, any advice would be appreciated
There isn't any good lift kits under 500
cheapest you can get into is 750-800 and thats with some good shopping
This is a full spring liftlike Ironman or OME
Only way you want to go is full spring
Stay away from Skyjacker, Rustys etc and ANY spacer style lift
nocTurNalX
GA
Welcome! Definitely avoid some cheap kits, do it once and do it right. Hunt for some sale deals from good retailers, especially on OME.
wdwillson
michigan
I just finished my spring/shock lift for <700. 659.00 I think! I did a lot of shopping around. I added two clevis bushing for @ 10.00 each. it took about 8 hours total. The next one would take about 3ish. if you don't include the bushings. I had access to a lot of tools and I put the struts together myself.
wdwillson
michigan
Sorry ,, here's what I used
ome 927's with bilstein 139168's up front
ome 948's with bilstein 185660 (I think)in the rear.. if you buy these by the numbers, you'll also need the install kit because this ( rear number) is not the correct fitment for the liberty. I fabricated what I needed to, but for the cost of kit from jba, I'd use the kit next time.
