Simpleman
I started using the 0W-30 Mobile 1 Syn yesterday, and now have that dreaded timing chain rattle for a few minutes after start up. Anyone else using 0W-30, and notice this?
The 4.0L engine and the 3.7L have NOTHING in common. What's good for the 4.0L, isn't necessarily good for the 3.7. 0W-30 isn't thin and it's not a$$ oil. It's a 30 weight, just like 5W-30, 10W-30. Do your homework next time before replying.all I use is 10 30
mobile 1
in my Jeeps
I have run 10 30 in temps down to the single digits in a TJ 4.0 ,know for lifter knock
and have no issues
The problem may be from the this a$$ oil you put in there
car calls for 10 30 on the oil cap ,put that
any thing else is to thin
I know that the TJ uses the engine oil in the lifters and when it is very cold the 4.0 will knock for a few minutes but even out quickly
same goes for the 3.7 in the KJ
Great filter. Are you using Mobil 1 Advanced Fuel Economy?I`m using a Puralator Pure One filter.
J-Thompson: My cap says 5W30.
I believe so.
RageofFury
My cap on both Jeeps reads 10 30
That is what I put
My F250 5.4L gasser that I push to the limit calls for 5 30 ,on the cap
That is what I put
any thing else is WRONG
but hey if you want some lube power I had some Mexican food the other day and boy
that stuff will lube up the system if you know what I mean
OH and FWIIW I was refering to the fact that both the 3.7 and the 4.0 have Hydro lifters
I know that the 3.7 and the 4.0 have nothing in common
the 4.0 is........
the 3.7 is not......
But has a drastic effect on engine longevity.Those thinner oils(0w and 5w20's) are really not the ideal oil weights for your engine as they are used only to meet the federal mpg standards and the cost of your engines longevity.Just wait they just raised the mpg standard by almost 10mpg's for 2016,expect 50k-100k engine changes will be the norm when running 0w10 oil and thinner in the diffs.I am trying the 0W-30 because it says it exceeds the requirements of 5W-30, and is better on gas. The oil has a reduced viscosity while cold but it is still 30 weight oil.
0W-30 is still a 30 weight oil though. It's not thin. 5W-20 is thinner yes, since it's a 20 weight oil.But has a drastic effect on engine longevity.Those thinner oils(0w and 5w20's) are really not the ideal oil weights for your engine as they are used only to meet the federal mpg standards and the cost of your engines longevity.Just wait they just raised the mpg standard by almost 10mpg's for 2016,expect 50k-100k engine changes will be the norm when running 0w10 oil and thinner in the diffs.
Been running Mobil1 extended performance 5w-30 since mile 100 in my KJ,zero issues and now at 70,250miles(get's changed every 3k no matter what).
I use the blood of the innocent in my engine.
