farmjeep04
Had the water pump loose the bearing and through the coolant under the hood everywhere. Replaced water pump and alternator while apart. Battery was unhooked for about a week Until I got it done. Started up after fix and seemed to run fine. Drove it around and now is skipping at idle. When driving or reved up skipping goes away and seems to run better then skips at idle. changed spark plugs last summer. Seamed to be running fine before water pump blow up. any thoughts would be helpful thank you
