02 Manual engine swap with automatic
matieschyn
canada
Hello there, my 02 liberty renagades engine recently bit the biscuit. The most cost effective option i've priced out was to get a used low K engine from a recker, i was able to find a 02 engine from a sport for $900 with 132k on it. However, it's from an automatic liberty...mine is a manual transmission, will this used engine fit?
Regards
4x4kayak2112
tx
Should....its from the flexplate back that would be different.
Sent from my Home Phone using Tapatalk
X2
The ****** doesn't matter - the bolt pattern around the bellhousing is the same.
JeepCoMJ
SE WI
you will need to install the pilot bushing in the crankshaft and swap the flywheel onto it, obviously
