You can use one relay for the Renegade light bar, no problem there that's the way its done from the factory. So buy a couple 30/40a relays from the local auto parts store and use the great diagram Jeepster posted above, that's the same as the instructions that come with the Hella driving lights, for your Renegade light bar.
One change though, you mentioned the other two were fog lights, you might want to wire constant battery power to the switch to turn the relay on and off for them instead of tapping to the high beam wire for the headlights, that way you can turn them on and off whenever you want. Or wire to the low beam wire at the headlights so you can have them on with the low beams when your switch is on, and they go off with the high beams, thats how most fogs work from the factory.
And if you don't want to run all that wiring through the firewall you can tap off the high beam and low beam fuses in the interior fuse box, drivers end of the dash, to feed your switches instead that's how i did mine. Just get a Tapa-Fuse from the auto parts store for a Mini-ATC fuse. You unplug the stock fuse, plug it into the tap and then put in a second fuse and plug the whole works into the fuse box. It's also nice because now your fuses are right there inside. I used a 1a fuse to feed the switches as Hella puts a 1a in their wiring kit, but also because all the switch needs is enough current to trigger the relay and if its a lighted switch it will also draw for that off its feed. I measured the current and with the switch on and the relay coil energized its just about 1/2 an amp.
My pair of Hella 500FF's draw about 9.2 amps as measured, so the 16awg wire it came with for the short run from the relay to the lights was plenty for my use otherwise i would have grabbed a spool of 12 or 10awg off the shelf.
