windshield washer nozzle
Has anyone attempted to adjust the spray angle from the nozzle?
The nozzle is one whole plastic piece and thus not adjustable. my DS sprays a little too high.
Anyone have any thoughts?
Thanks.
rjkj2005
US
They are non adjustable. They are set hight so at highway speed spray correctly. Supposedly
Never really had an issue with mine. Is it hitting close to top of windshield..video?
I suppose as long as glass get wet, you are good to go.
Other option= mod where you disconnect those mounted nozzles, get a T-Junction, and run the hose with fine holes, flat along the arm/wiper blades.
56238[/ATTACH]"]
yeah. it hits high but not way above the windshield, just a few inches below the top arc of the area of the wipers make so the bottom left part doesn't get hit with the washer fluid.
I might try to see how the one piece nozzle sits on the cowl grille.
Or convert to a clip on arm system nozzle...:winner_third_h4h:
56240[/ATTACH]"]
Then you will have a Master Blaster system! :gr_grin:
56242[/ATTACH]"]
Not to hijack but anyone ever replace just the nozzle or do you have to replace the whole cowl. I tried to find the nozzle a few years back and no luck. My driverside is messed up and just dribbles at a spot just above the wiper.
Try cleaning it out with a sewing needle...Probably plugged up?
No worries. I think there was only 1 or 2 other threads on the forum.
You should be able to purchase the nozzel and replace it but you'll need to remove the cowl to get it out.
Part fische has it as 55155854AB.
Maybe you can remove the current on and try to back flush it or soak it in some detergent.
Actually the opposite. I think the PO might have reemed it out trying to clean it and it is too big of an opening so no force to get up the window.
REALLY appreciate the part number! I'll be ordering one today. This thing has driven me nuts for a long while and I could never find the part no matter what I searched. I pretty much gave up until I saw this thread. I think I owe you a beer or three! (Cheers)
Ordered nozzle and found the instructions in the FSM.
Never removed the cowl before and hate the phrase "remove the 4 plastic retainers". Should just say mess up the 4 plastic retainers. Better yet, for reinstall, it then says to reinstall nine clips to the windshield (not in disassembly) and reinstall 5 plastic retainers. I love the FSM. :favorites68:
ltd02: where do you see those instructions?
i looks like it's:
1. remove wipers
2. remove cowl
3. remove hose
4. remove nozzel
reverse order for installation.
also while you have your cowl removed, you might as well clean the "air filter" on the passenger side.
teeje
Toledo
Those retainers come out easily without messing up. They're not the "Christmas tree" ones
ltd02 I want to hear how the cowl plastic retainers go as well. Is there any removal tool for them? (ha ha a wide fork? LOL)
May want to have a shop vac there too, cause you will probably find that the air intake screen needs debris vacuumed out. Also good time to inspect the seal.
Take photos of the nozzle replacement, also any debris on screen?
i looks like it's:
1. remove wipers
2. remove cowl
3. remove hose
4. remove nozzel
Right, sounds simple but step 2 above (the cowl removal) in the body section (23-140 in my FSM) has the "retainer and clip" info. :Wedgie:
Thanks! That is encouraging. I'm not noted for being gentle on or patient with those plastic clips and retainers. :gr_grin:
I'll definitely clean everything I can while in there and try to post some pics. :favorites13:
Yes that's a HUGE help. I have had luck with those type retainers before. I had them on a different vehicle and learned by trial and error already so feeling pretty confident now. The filter idea is a must do now. Wish I had the nozzle so I could do it tonight but won't be here until about Wednesday and my KJ is the daily driver. :happy107:
