Will these fit..?
2023matt
Illinois
I was looking to replace these with the stock fog lights on my 2006 Liberty Renegade
Anyone know if they would be a direct fit for me as well?
If bumper mounted then more than likely yes
stock ones were made by Hella by the way
Of course those are not fog lights if thats what you want to replace
2023matt
Illinois
Ok so the wiring should work too?
Tog
AU
Pretty sure the fogs on my 04 are not completely round the top is flat a full round light may not fit
2023matt
Illinois
I'm talking about the outside fog lights
And here is what it is mounted to by the way...
O5berylgrnrenegade
Canada
If the back of the lights are to bulged they will not direct fit the factory fogs have the mounting point set back on the light most aftermarkets dont have the mount far enough back to clear the grille on my 05 renegade i had to make some steel extensions to bolt into the factory holes to clear my led fogs and their flatter than the one youve posted by at least a 1/4 inch
O5berylgrnrenegade
Canada
Even if the wiring doesn't plug into them (which I doubt it's plug and play), it's not exactly hard to wire up lighting..I'm sure with some insight or guidance you could get it figured out easily.
Just cut the factory plug off leaving some extra wiring solder heat shrink and plug back into the factory harness its how i did mine
Yes 2 minutes to make a short bracket to move the lights out a bit
GunnerSchenck
Pretty much exactly what I was referring to. Just meant that we could help him out if he didn't know where to start or what wires to connect..lol I stated it wasnt hard..
