White smoke and burn smell from rear wheel?
squirrellydw
PA
I pulled into my driveway and when I got out I noticed white smoke and a burning smell coming from the passenger side rear wheel, anyone have this happen before? I had it towed to the dealership and they are going to look at it tomorrow. I am thinking that the brake was stuck on some how. I never use the e-brake so it can't be that. I tried a search but didn't really find anything.
oh and I have 27,000 miles on it.
hyde
I smell burnt rubber all the time, but no smoke so far, other than when driving through water...
2003KJ
Planet Earth
tjkj2002 said:
I think there is a TSB on something dealing with the rear brakes,just can't remember right off hand.Most likely a stuck piston in one of the caliphers.
Yup.....might want to have the brake pad and rotor inspected real close while its there. And you say 27K, so i'm assuming still under warranty. There's a good chance that the pad and rotor were damaged from excessive heat...
thecause17
North Huntingdon, PA
I heard of a problem a while back with the rear rotors glazing over and causing noise issues. They were being replaced under warranty for a certain milage, like 12k miles, which I think is all that brakes are covered for, being a wear item and all. I never had such an issue with mine, and my rear rotors looks to be original at 42k...at least the rear pads were also until I changed them last week.
libertydude
NH
happened to me..
I left the dealership for an oil change.. and the rear tire locked up.. on the highway.. brought it back.. dealer said nothing wrong here.. took to another 5 star (joke) dealership.. they replaced the rear calipers/rotors/pads.. so it will most likely happen often.. my kj is being traded within 2-3 weeks.. ordered a jk with antilocks etc. can't imagine why something as simple as brakes will fail.. what is this a cordoba?
oh and do you sense I'm angry... why yes.. when a dealership claims it didn't happen.. and another dealer says I see they turned blue they got so hot.. and if you google this issue.. tons of complaints.. and all the dealers say.. wow.. never seen this before.. GET ON THE INTERNET PEOPLE!
KJ04
Grafton, Ohio
When my rear caliper went, my dealer said the calipers were on national back order, which means there's a real problem with them. They finally located some at another dealership fo me.
squirrellydw
PA
They said it was the caliper stuck. I didn't find out if they are replacing the rotor yet or not.
interesting over 74000, original brakes all the way around and no problems I would never go as far as trading it off for a JK just for that
reload40s
Pittsburgh, PA
Re: happened to me..
(Ricardo Montalban) But the Cordoba had rich Corinthian Leather and a smooth Ride!!(Ricardo Montalban) (naughty)
vXxo0oxXv
I had a burning smell coming from one of the wheel wells once after doing some wheelin. Turns out the brakes were cooking mud that was caked inside of the wheels. Mmmmmmm
hyde
There is a goalkeeper called cordoba, from argentina, but that's not the point now.
Yes it is.......he was probably named after that car......oh, and I remember the cordoba, and the rich corinthian leather, and the Ricardo Montalbon commercial........I guess I'm too old.
By the way, you guys really know how to twist a thread around.......and of course I 'm just throwing more wood on the fire.
