What is the deepest water a KJ can drive through
yellocoyote
The rear breather you can extend up alongside of the outside of the gas tank filler tube, and the front breather I have extended up to the neighborhood of the battery.
yellocoyote
You can replace the tubing all the way from the source with 5/16" fuel hose to make a seamless extension, or you can buy hose barbs and the hose to extend your current lines. Depending on the condition of the current breather tubing (weather, dry-rotting, etc), It may be worth it to replace the entire length of tubing.
JLRockies
Draper, UT
Do not attempt with spark infestation and without a strong sense of gangster.
yellocoyote
This must have been your method to prevent it from overheating, right? ;)
