Luke
Interloper
Question on your lift, did they ship that to you, or did they have to install it?You must be registered for see images attach
It was long ago … but yes, shipped from All J’s to Canada and I installed it. Sadly it’s discontinued, but there is a helpful parts list still there.Question on your lift, did they ship that to you, or did they have to install it?
Why does this seem familiar....You must be registered for see images attach
Probably because you too have been taunted by GLaDOS.Why does this seem familiar....
thought it was time for an update after finally getting rid of the front end clunk. last weekend finally got around to doing the clevis lift and now sitting at 21&1/2" at the back and 21" at the front also made up a transmission skid plate and bolted that on. then went for a drive up to my hut in the back country which can be a bit treacherous with 8 river crossings each way and shingle river beds to traverse. thought i would take a short cut and see how far i could get and as you can see from the photo, not very far before i completely sunk in soft wet gravelYou must be registered for see images attach
after a quick tow back out went the rougher longer way and finally made it up to the hutYou must be registered for see images attach
You must be registered for see images attachYou must be registered for see images attach
the skid plate is made from 4mm steel plate with the edges turned up to give a bit of strength and slotted at the front to slide in between the front cross member and front skid plate, and a few drain holes and hole to get at the oil drain plug
hi, i live in New Zealand so probably not really practical, but total cost was under $75nz, just made up a carboard template firstNice plate, how muc to make one for me?
Never heard of it.Probably because you too have been taunted by GLaDOS.
https://en.m.wikipedia.org/wiki/Portal_(video_game)
Did the same Sunday, and apparently I forgot everything I ever knew about shooting. Couldn't hit the broad side of a barn at first. Improved near the end. Still and all, best I managed was 60 points south of a Rifleman patch.Took the Liberty to work today, taking my son and I to day 1 of 2, of a local Appleseed shoot. Came within 15 points of getting my Rifleman patch. Would have done better if I'd not gotten tired at the end. Spending all day in an outdoor range in 90 degree temps (before the heat index is calced) will really take it out of you. Especially when you are doing it on 3 hours sleep.
About to hit the shower, take some ibuprofen and acetaminophen, and hit the rack... Back out to do it again tomorrow.
I just ordered my links for ;my 2007, and some new bushings. That rear upper on mine needs done, not sure if its the same on the new models, I have the boomarang shape one.It’s been an eventful week and weekend on the Jeep front for me.
On Wednesday we sold our 07 Jeep Commander so we are back to having just one vehicle, the 08 KK Liberty. The Liberty had been parked for a month due to a bunch of work that needed done, but the safety issue was a rear upper control arm bushing that had disintegrated. So, this weekend, I went all in on repairing the Liberty and getting it road worthy again.
In the last two days I…
- rebuilt the front driveshaft with a new transfer case end CV
- installed the front driveshaft
- installed the passengers side rear upper control arm
- oil change
- dropped the fuel tank
- installed the drivers side rear upper control arm (fuel tank blocks a critical bolt)
- reinstalled the fuel tank
- test drove it, found a clunk in front
- removed drivers side sway bar link which had a seized bolt. Melted the rubber bushing on the link in the process
- test drove it again, clunk went away
- ordered a pair of Mopar sway bar links
- ordered a pair of Mopar rear bump stops as the originals were disintegrating
So, no highway driving for Jeepy until the front sway bar links are installed, but she is ok for grocery getting and taking me to work. It is supposed to rain all week so I am happy to have a working vehicle!
Always wanted to go there, luv watching the crime dramas I get on BritBox and Acorn with New Zealand as the filming locations. Do they call the liberty there the liberty, I though in Australia and NZ they had a different name.hi, i live in New Zealand so probably not really practical, but total cost was under $75nz, just made up a carboard template first
Pretty sure it's pronounced 'Cherokee' over there...Always wanted to go there, luv watching the crime dramas I get on BritBox and Acorn with New Zealand as the filming locations. Do they call the liberty there the liberty, I though in Australia and NZ they had a different name.
Yeah as far as I know everyone outside of the US got a Cherokee and a Grand Cherokee.Pretty sure it's pronounced 'Cherokee' over there...
yep NZ and Aussie it's called a Cherokee had it for 17 years now.Always wanted to go there, luv watching the crime dramas I get on BritBox and Acorn with New Zealand as the filming locations. Do they call the liberty there the liberty, I though in Australia and NZ they had a different name.
