seafish
Yesterday I pressure washed Giddyups underside to prevent as much dirt as possible from falling into my eyes as I dropped her fuel tank in order to install the new Lift Pump. I also used a swivel ratchet adapter with an extension and impact driver to loosen the tank straps, so I did NOT have to drop the hitch like others suggested I would need to do first. FYI — the hitch is only in the way for loosening the rear bolts on the tank straps, NOT at all for lowering the tank.
That said, NO ONE told me about the stupid fuel line connections!!!
I mean I knew they would be challenging, but had NO idea that I could have gotten a couple of fuel line disconnect "sleeve" tool for a few dollars, which would have saved me a TON of time.
Instead I had to stop and drink a beer just to be able to cut the can apart and make a shim that would slip in between the internal locking connectors and the fuel lines. Definitely need to triple fold the beer can to make it strong enough to do what it needs to do while still being thin enough to get there. NOTE that after folding, the shim still needs to be at least 3/4" wide. I also "pre rolled" it around a 5/16" bolt just to make sure it would slip in around the fuel lines and contact the clips on the connector. Finally I used an open end wrench just bigger then each line to push down on the shim while still pulling the line and connector apart.
Once I figured out what I needed to do (obviously the beer helped), the larger line came apart fairly fast, but the smaller one was a real b***h !!! Not sure why Sasquatch, who makes the LP kit I was installing, doesn't offer to sell a couple cheap but properly sized fuel line disconnect tools when you order the kit…in fact, Im gonna call him on Monday and suggest that he does just that. Or at least include a free beer in the kit with instructions on how to make one from it. ;)
After swapping out the fuel sender float from the old canister to the new one, cuz of course the 1/4" difference in arm length wouldn't calibrate the gauge correctly, and despite cutting down the orientation key/tab, the pump housing kept turning slightly on the tank as I was locking the ring down on the new o-ring…despite using grease and pressure and at one point even my wife standing on it. It took a bunch of hammering back and forth, thankfully without breaking anything or hitting my wife with the hammer, and I got it all aligned and sealed up tight.
Finally, and as I was reinstalling the old fuel lines on the new lift pump housing, I realized how loose the connections felt and that this was likely at least one of the places where air was leaking in under vacuum from the HPCR pump, which means diesel would soon be leaking out under pressure of the new lift pump!!! Rather then replace the terribly designed but nicely form fitted OEM hoses with new raw fuel hose and clamps (I didn't have any of one of the sizes and town is a one hour drive each way), I simply wrapped them tightly in overlapping self sealing silicone tape and then threw a few small zip ties on each one to keep the tape from unravelling over time. They're gonna be a b***h if I ever have to remove them again, but IMO for 12psi, it's gonna work fine to keep any leaks from happening. I'll do the same on the other ends just in case.
YAY for pressure washers, beer, beer cans and silicone tape!!! :)
That said, the various stupid complications made the whole project last more then the half day I allotted, so Im still gonna have to finish it tomorrow. :(
Been spraying some Lanolin based rust prevention on the inner wings, inside and out ready for next winters salt so I've had the battery carrier and air box out, found the knock on my steering, the fine gentleman who fitted the new steering rack before I bought it hadn't fully tightened the UJ clamp bolt! Wish I'd chased it sooner, I just assumed it was going to be bushes, all nice and tight with the pinch bolt torqued so I guess the splines are ok, I don't want to take the rack out to check!
And I need a new upper arm, the ball joint has play, hopefully tomorrow will be dry.
seafish
In order to finish off the in tank LP install, I drilled a hole in the unibody, behind the drivers seat and under the carpet, for the new lift pump ground connection. I scraped the paint back but also used a couple of small "star" lock washers to better lock the wire unto the bare metal. Hooked up both ends of the LP harness and then reattached the battery ground terminal all so that I could check that the "Hecho en China" Airtex/Carter (or is it Carter/Airtex??) pump actually works BEFORE reinstalling the tank. Crossed my fingers and said a quick prayer to the Chinese parts god, turned the key and the new pump purred to life inside the tank and shot fuel out the supply side. Win!!!
Then with help of awesome wife and a floor jack, I got the tank lifted back up and bolted in, fuel lines hooked up and sealed with silicone tape, harness properly routed and zip tied to avoid the moving suspension parts and finally the filler and vent lines reattached. Note that I probably should have drained or run the tank down more then I did (was about 1/3 full), but with the extra help it was not really a problem.
Lowered Giddyup to the ground again, turned the key and she started with her oh so cute snort like she always does … I like to think even a little quicker then usual. :cool:
Looking at replacement UCA's I have a second hand one I'm going to stick on to keep me mobile but I will probably need some replacements soon. The supplier has these listed, never seen this type before, anyone used them?
Just hangin' out.
Wifey had major surgey and is recovering well, so finally had some time to work on Bert in between wound care and drain purges (gross even by Biologist standards)...
Replaced starter.
Greased the JBAs.
Cleaned the snorkel pre and post filters.
Re-wired the rear spot lights.
Polished headlamp lenses.
Cleaned the Odyssey battery contacts.
Replaced broken plastic window regulator clip with the steel version. ( only one I didn't do when I owned Bert)
Have a ton of cosmetic work to do as son-in-law is a lazy bastard and can't grasp the concept of hosing off the road salt...
Other wise, Bert is in pretty good shape for 375k miles on original drive train.
seafish
Today I managed to strip the threads of the oil pan while replacing the drain plug for a 10k oil change. I wish that I could blame some grease monkey at the dealership, but turns out that I AM the grease monkey. :mad:
I did some reading on LostJeeps in order to determine the bastard Italian thread size (nothing I have here in metric or SAE matches the plug exactly, though both 3/8" IP and M16 -1.5 are close) I learned that its an M16.4 - 1.33 . WTF???
That said, I also learned that between the ridiculous OEM straight and shallow threads and the combination of a stainless steel plug going into an aluminum pan, that stripping the oil drain plug on a KJ CRD is NOT that uncommon. I still feel stupid, but maybe not quite as much.:(
Since I like the ValvoMax quick drain plug that I installed on my Dodge Ram CTD, I'm gonna call them tomorrow to see what they have in next size up for the Jeep that I can drill and tap the pan to. Stay tuned.
CheddarGau
Lower Mainland BC
I wouldn't feel too bad about it. Happens more than you would think on many brands. Ford 3.0L and 2.0 and 2.5 are bad for it. Honestly you can just tap new threads in the same, or you can cut to the next size up, heli coil and put in whatever fits that size that is common. Nothing says you need to go with the same size.
derekj
Powell River, BC
That definitely is not for a Liberty - probably just used a stock photo for the listing I would guess.
seafish
Turns out that both Valvomax and Fumoto sell their easy oil drain valves for the KJ CRD with a 3/8" pipe thread for the oil pan. When held right up against the OEM drain plug, the 3/8" pipe thread was damn close to the bastard M16.4-1.33, with the exception of being tapered. That being the case, I took a 3/8" IP tap, greased it well to hold any chips, and and ran it all the way into the oil pan. It threaded in easily with minimal effort and when I removed it, there were many, but only tiny, chips stuck in each greased flute. The new threads looked straight and clean, so I threaded in a 3/8" pipe fitting which tightened up nicely as it got near the end of the taper.
I entertained the idea of just using a 3/8" brass pipe plug that I have on hand in order to get Giddyup back on the trail, but instead decided to order and wait for the Valvomax unit, and then install it in the aluminum oil pan, with either Loctite 272 or JB Weld, and then I'll never have to worry about the drain plug stripping out the oil pan again.
This is what I ordered (with a 20% discount just by signing up for their emails)
I am considering a PML aluminum pan for the transmission.
With wheeling and towing, this will help keep the fluid cool. I have an aux transmission cooler in front of the radiator but it doesn’t help much unless I am driving fast enough to dissipate the heat.
My transmission has 229k miles on it and is still kicking. I have a reserve 42RLE VLP unit with only 80k on it for when the time comes. It has been sitting since 2022! I’ll fix the rear main seal when I swap in the reserve transmission at some point.
seafish
I put one on Giddyup when I got her for the drain plug and extra capacity…any additional cooling would be a bonus. That said, it is a sturdy, nicely cast and also well machined piece of aluminum. IIRC uses a nice O-ring to seal as well, though IMO there was no reason to spend extra $ for the anodized black version.
Thank you for this feedback! I may yet go for the plain silver one.
