Dillema:
or...
Prices per switch position are comparable. The 6 uses a traditional relay setup and could handle more power. The 8 uses IGTs and is maximum current limited.
I actually have a relay box like in the first one already, as I was going to roll my own with one, but I love the neatness of the wiring that kit gives you.
Thoughts
Leeann
Maryland
What are you using for Rust Converter? I usually get Rustoleum, but last night picked up Loctite's version as it said it's supposed to be a little glossy.
I have Loctite Extend here, but a guy on another forum recommended Corroseal, so I've been giving that a try. It smells like Elmer's glue, but it seems to work pretty well.
You have a link for those? I like them. Maybe it would get me moving on upgrading the switches I have now.
pictures are links :D
also I think I'm leaning towards 6-switch version. I like the idea of relays instead of IGTs for switching.
eta:
https://www.ebay.com/itm/6-Gang-Swi...3cf2e2147:g:yH0AAOSwHv1eIWqz&autorefresh=true
$75.90 for the 6-gang.
I put an offer in for $60 :D
useful shot of some of the bits.
one of the biggest problems I see is, I'd like to mount that on the driver's side, but there's really no room there. I guess if the control line is long enough to reach the passenger side, I could put it there. I'll need to relocate the plow control module though.
actually looking more closely at the picture, I think the bottom cover with the wire cutout comes off, and could be installed in the other direction.
That 8 position bracket is just a tick over 8.5" wide. Says to me I could do 2 of those switch panels easily.
GitEmSteveDave
Howell
I usually use it on my door panels and in the engine bay. I don't mind flat black from rustoelum RR on the inside of my door panels, but I liked the idea of glossy. I only had a chance to do one coat yesterday of the Extend, and didn't notice it covering like the RR does, but the can was ~40F and it was cold out, so maybe I'll wait to a warm day and keep the can inside.
Leeann
Maryland
On the Loctite Extend, I use the bottle where you paint it on with a brush. I've never had any luck with the rattle can version.
POR-15 sprays beautifully out of a $10 HF purple paint gun.
GitEmSteveDave
Howell
Found someone willing to part with a stock lightbar switch. Finally no gaping holes in my dashboard!
wanna give me your blank out plate? :D
How are people cleanly getting wiring up to the roof for lights on a rack, without drilling through the roof or the body work?
from engine bay, under cowl, remove the moulding up door frame, wiring runs under it up to top side, when I ran mine had less than 1/8 of inch of wiring showing
JoeManly
Gifted Rabbit Hole Finder
Chelsea, MI
So all last year I took on the major project and after dropping a remanufactured engine in, rebuilt the trans, installed new front driveshaft, refurbished the rear driveshaft and axle, new upper and lower control arms front and rear, all new links/bushings/ball joints, brake rotors/calipers/pads/drums/shoes, new front and rear stainless brake lines, new parking brake cables, complete new cooling system, PCM, TCU, BCM, coil packs, fuel injectors, every sensor, complete new exhaust including cats from 1 year prior, but now new O2 sensors, LED headlight conversion, rocker panels and a partridge in a pear tree.....(big inhale), I was having the windshield replace so by golly what better time then to Raptor Liner the whole thing. The inside is totally clean too, but the outside is just sexy.
Leeann
Maryland
Returned the old front calipers for the core charge and bought rear pads and rotors. They're actually worse than the fronts were...
GitEmSteveDave
Howell
That's what threw me as well. There's no rattle in the can. Didn't realize it came in a regular liquid.
